Téma: clon tonsil
Tak jsem udělal na rychlo clon tonsil vyrobeno v Canadě ,prodejní cena 500 US
gdn 13/40/2,4+ gtc 10/80/8. já jsem použil identický středobas kulatý koš. objem 5,6 l nebo 11 l, nebo 20 l ja jsem to vsunul na rychlo 9l na zkoušku,vyhybka je 6/6 db.byl jsem mile překvapen.
FEATURES
• Usable in two-channel music systems and in home theater systems
• Standard finish matte black. Genuine mahogany finish available
• Lock miter cabinet joints. The mahogany version is veneered on both the inside and outside.
• Twin pairs of solid gold-plated binding posts
• No-compromise drivers, wiring and crossover parts
SPECIFICATIONS
Dimensions: 270 x 152 x 227 mm (11 x 6 x 8.5" approx.)
Volume: 5.6 litres (internal)
Weight: 4 kg (9 lbs approx.)
Crossover frequency: 3.2 kHz electrical and mechanical
Impedance: 4 ohms
Frequency response: 50 Hz to 20 kHz ±3 dB with correct positioning
Sensitivity: 87 dB/W/m. Maximum SPL 102 dB before dynamic compression
Minimum power: 20 watts at 4 ohms
Maximum power: 80 watt
Recommended stands: Totem P2S
FEATURES
• Specially designed to be used as the center speaker in a home theater system
SPECIFICATIONS
Dimensions: 524 x 152 x 227 mm (20.5 x 6 x 8.5" approx.)
Volume: 11.2 litres (internal)
Weight: 8 kg (17 lbs approx.)
Impedance: 4 ohms
Frequency response: 46 Hz to 20 kHz ±3 dB with correct positioning
Sensitivity: 88 dB/W/m. Maximum SPL 105 dB before dynamic compression
Maximum power: 100 watts
FEATURES
SPECIFICATIONS
Impedance: 4 ohms
FEATURES
SPECIFICATIONS
Impedance: 4 ohms
Specifications
